[Geoserver-devel] [jira] Created: (GEOS-4707) Overlay map size
Overlay map size
                 Key: GEOS-4707
                 URL: https://jira.codehaus.org/browse/GEOS-4707
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.1.1
         Environment: Windows 7 64bit version,
            Reporter: pelani malange
            Assignee: Andrea Aime
         Attachments: Page loaded.doc
I am a newbie to geoserver and have gone through internet searches and read the manuals for the problem below. No fix.
I setup the geoserver and uploaded shp files for Malawi with ESPG code 20936. When i use layer view and click openlayers within geoserver, the map opens with no problem and centers accordingly. However, when i use openlayers/examples/lite.html or any pages to see the map, the map does not zoom to center (lon,lat) and scaling does not work. However, using the same lite.html, I am able to connect to other WMS servers and the shp file is correctly fitted.
Please help
