Problems running WorkspaceNamespaceConstencyTest
Key: GEOS-4715
URL: https://jira.codehaus.org/browse/GEOS-4715
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.1.1
Environment: Windows 7, git svn checkout, mvn
Reporter: Walter Deane
Assignee: Andrea Aime
testChangeWorkspace has an error. A warning is output to console that says: WARNING: Could not delete C:\Users\wdeane\git\geoserver\src\main\.\target\mock2896908706445719443data\catalog.xml
The output copied from eclipse for the error is:
testChangeWorkspace(org.geoserver.catalog.impl.WorkspaceNamespaceConstencyTest)
java.io.FileNotFoundException: .\target\mock3033434871127789817data\styles\Default.sld (The system cannot find the path specified)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(FileOutputStream.java:179)
at java.io.FileOutputStream.<init>(FileOutputStream.java:131)
at org.geoserver.data.util.IOUtils.copy(IOUtils.java:51)
at org.geoserver.data.test.MockData.<init>(MockData.java:327)
at org.geoserver.test.GeoServerTestSupport.buildTestData(GeoServerTestSupport.java:35)
at org.geoserver.test.GeoServerTestSupport.buildTestData(GeoServerTestSupport.java:29)
at org.geoserver.test.GeoServerAbstractTestSupport.oneTimeSetUp(GeoServerAbstractTestSupport.java:173)
at org.geoserver.test.OneTimeSetupTest.setUp(OneTimeSetupTest.java:89)
at junit.framework.TestCase.runBare(TestCase.java:128)
at org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestReference.run(JUnit3TestReference.java:130)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197
