[Geoserver-devel] [jira] Created: (GEOS-4716) ImageMosaic plugin does not display adjacent granules.
                 Key: GEOS-4716
                 URL: https://jira.codehaus.org/browse/GEOS-4716
             Project: GeoServer
          Issue Type: Bug
          Components: Image mosaic JDBC
    Affects Versions: 2.1.1
         Environment: RedHat Linux 5.5, JVM 1.6, Tomcat 6, Native JAI, Native JAI ImageIO
            Reporter: Nick Lebedev
            Assignee: Andrea Aime
There is a problem displaying an ImageMosaic layer through WMS GetMap.
The request returns rendered raster from only one granule at a time, so
when several raster granules fall into the bbox of the request, only one
of them is rendered, others are blank.
When I move a map a bit, so the granule,that was blank is the only one on
the map, it gets rendered ok.
When I make a GetFeatureInfo request on this blank granules, it returns
the correct GRAY_INDEX.
I've done a couple of screenshots to illustrate the problem:
This is what it looks like
http://db.tt/oHWR8jC
The black grid is a shapefile generated by the ImageMosaic plugin.
And when I move a map a bit south, another tile shows up
http://db.tt/y4c3foJ
The rasters, that I'm using are here:
http://db.tt/IkVRPGQ
This is the workspace and the store configuration xml files from geoserver data dir:
http://db.tt/s3p29yr
They are just hillshade files made with gdaldem hillshade from initial srtm rasters. They do not overlap, they are correctly referenced GeoTiffs, and they are all of the same size
I've tried to test this issue on a different environment: Mac OS X Lion + JVM 1.6 + Tomcat 7 + GS 2.1.1.
When trying to add an ImageMosaic store from the GUI, I get an error:
"Could not list layers for this store, an error occurred retrieving them: Unable to acquire a reader for this coverage with format: ImageMosaic"
GS log of the error is here:
http://db.tt/lWnWmHz
This is my personal computer, so I can provide access to it if needed.
