[Geoserver-devel] [jira] Created: (GEOS-472) Combine various eclipse set up information
         Key: GEOS-472
         URL: http://jira.codehaus.org/browse/GEOS-472
     Project: GeoServer
        Type: Task
    Versions: 1.3.0 RC6
    Reporter: Chris Holmes
Assigned to: Brent Owens
    Priority: Minor
     Fix For: 1.3.0 RC7
http://docs.codehaus.org/display/GEOSDOC/GeoServer+and+Eclipse+with+Tomcat http://docs.codehaus.org/display/GEOSDOC/GeoServer+and+Eclipse+with+Jetty and http://docs.codehaus.org/display/GEOSDOC/Debugging+with+Eclipse+and+Tomcat all repeat a lot of the same information, contributed by various people at various times. The last I think is the oldest, and can probably just be killed. The common elements should be comined, and then just differentiate on includes for Jetty or Tomcat. Also should take into account the geoserver set up tutorial, and make sure one is more tutorial like, the others more 'reference', if possible. But at the very least just cut down on repeated information and confusion for users as to which they should use.
For more information on JIRA, see:
