[Geoserver-devel] [jira] Created: (GEOS-4722) Manage styles: Show layers using current style when editing style
                 Key: GEOS-4722
                 URL: https://jira.codehaus.org/browse/GEOS-4722
             Project: GeoServer
          Issue Type: Improvement
          Components: Wicket UI
    Affects Versions: 2.1.1
            Reporter: Serhat Gulcicek
            Assignee: Andrea Aime
            Priority: Minor
Just a suggestion to improve user-friendliness. If the layers are shown that use the style that is currently being edited, an user will know on which layers it will have an impact on. This for both testing purposes later on and as an extra check to see if you are editing the style for the correct layer.
It doesn't have to be a big list, as some 'default' styles could be used a lot. Just showing one/a few/none suffices as long as there is a button/clickable span which will allow you to see the full list.
