[Geoserver-devel] [jira] Created: (GEOS-4727) WMS layer - SQL views seems to be leaking connections
                 Key: GEOS-4727
                 URL: https://jira.codehaus.org/browse/GEOS-4727
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.1.1
         Environment: OS: Ubuntu Server
Java: Java version "1.6.0_18"
Web Server: Apache Tomcat 6.0.24
DB:
- PostgreSQL 8.4.5 on x86_64-pc-linux-gnu, compiled by GCC gcc-4.4.real (Ubuntu 4.4.3-4ubuntu5) 4.4.3, 64-bit
- PostGIS 1.4.0
            Reporter: Serhat Gulcicek
            Assignee: Andrea Aime
When I was editing a lot of SQL views I was getting the exception below.
To reproduce the bug I restarted geoserver, went to an SQL view and simply hit "Guess parameters from SQL" and "Refresh" (below Attributes) a lot while also having "Guess geometry type and srid" checked.
After some additional tests I found out this only occurs if you have "Guess geometry type and srid" checked. Without it I can't seem to leak connections.
An assumption from my side is that the connection isn't closed(i.e. given back to the pool) properly in such a case.
java.lang.RuntimeException: Unable to obtain connection: Cannot get a connection, pool error Timeout waiting for idle object at org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:1621) at org.geotools.jdbc.JDBCDataStore.createTypeNames(JDBCDataStore.java:805) at org.geotools.data.store.ContentDataStore.getTypeNames(ContentDataStore.java:299) at org.geoserver.web.data.layer.SQLViewAbstractPage.testViewDefinition(SQLViewAbstractPage.java:322) at org.geoserver.web.data.layer.SQLViewAbstractPage$8.onClick(SQLViewAbstractPage.java:291) at org.geoserver.web.wicket.GeoServerAjaxFormLink.onSubmit(GeoServerAjaxFormLink.java:39) at org.apache.wicket.ajax.markup.html.form.AjaxSubmitLink$1.onSubmit(AjaxSubmitLink.java:68) at org.apache.wicket.ajax.form.AjaxFormSubmitBehavior.onEvent(AjaxFormSubmitBehavior.java:143) at org.apache.wicket.ajax.AjaxEventBehavior.respond(AjaxEventBehavior.java:177) at org.apache.wicket.ajax.AbstractDefaultAjaxBehavior.onRequest(AbstractDefaultAjaxBehavior.java:300) at org.apache.wicket.request.target.component.listener.BehaviorRequestTarget.processEvents(BehaviorRequestTarget.java:119) at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92) at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250) at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329) at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436) at org.apache.wicket.RequestCycle.request(RequestCycle.java:545) at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484) at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:160) at javax.servlet.http.HttpServlet.service(HttpServlet.java:637) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158) at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:809) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571) at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511) at javax.servlet.http.HttpServlet.service(HttpServlet.java:637) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74) at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394) at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109) at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406) at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101) at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406) at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105) at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406) at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116) at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406) at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91) at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406) at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278) at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406) at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89) at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406) at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235) at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53) at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406) at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185) at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298) at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859) at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588) at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489) at java.lang.Thread.run(Thread.java:636) Caused by: org.apache.commons.dbcp.SQLNestedException: Cannot get a connection, pool error Timeout waiting for idle object at org.apache.commons.dbcp.PoolingDataSource.getConnection(PoolingDataSource.java:114) at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:1044) at org.geotools.data.jdbc.datasource.AbstractManageableDataSource.getConnection(AbstractManageableDataSource.java:45) at org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:1613) ... 94 more Caused by: java.util.NoSuchElementException: Timeout waiting for idle object at org.apache.commons.pool.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:1134) at org.apache.commons.dbcp.PoolingDataSource.getConnection(PoolingDataSource.java:106) ... 97 more
