[Geoserver-devel] [jira] Created: (GEOS-4739) Rendering error on layer linked to Oracle view using with syntax
                 Key: GEOS-4739
                 URL: https://jira.codehaus.org/browse/GEOS-4739
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 2.1.1
         Environment: Windows 2008, java 6
            Reporter: kamardine
            Assignee: Andrea Aime
         Attachments: screenShot.JPG
Hello, i get the error in enclosed screenshot. If i send a getMap request including layer based on Oracle SQL view which using WITH synthax such as :
WITH
A AS(SELECT * FROM TAB)
SELECT COL1 FROM A
My sql view work fine, i tested in my Oracle database.
Best regards.
