GetCapabilities doesn't work with Internet Explorer
Key: GEOS-4748
URL: https://jira.codehaus.org/browse/GEOS-4748
Project: GeoServer
Issue Type: Bug
Components: WFS
Reporter: Florence Tan
Assignee: Andrea Aime
Making a wfs getCapabilities request in Internet Explorer (v8) from GeoServer build :
Version
2.2-SNAPSHOT
Subversion Revision
16259
Build Date
23-Aug-2011 22:04
GeoTools Version
8-SNAPSHOT (rev 37906)
will get a prompt "Cannot Start Application - Cannot continue. The application is impropertly formatted. Contact the application vendor for assistance." Click on the detail button will give you the following error :
PLATFORM VERSION INFO
Windows : 5.1.2600.196608 (Win32NT)
Common Language Runtime : 4.0.30319.235
System.Deployment.dll : 4.0.30319.1 (RTMRel.030319-0100)
clr.dll : 4.0.30319.235 (RTMGDR.030319-2300)
dfdll.dll : 4.0.30319.1 (RTMRel.030319-0100)
dfshim.dll : 4.0.31106.0 (Main.031106-0000)
SOURCES
Deployment url : http://localhost:8080/geoserver24Aug/wfs?request=getCapabilities
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of http://localhost:8080/geoserver24Aug/wfs?request=getCapabilities resulted in exception. Following failure messages were detected:
+ Exception reading manifest from http://localhost:8080/geoserver24Aug/wfs?request=getCapabilities: the manifest may not be valid or the file could not be opened.
+ Parsing and DOM creation of the manifest resulted in error. Following parsing errors were noticed:
-HRESULT: 0x8007001f
Start line: 0
Start column: 0
Host file:
+ A device attached to the system is not functioning. (Exception from HRESULT: 0x8007001F)
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
WARNINGS
There were no warnings during this operation.
OPERATION PROGRESS STATUS
* [2/09/2011 11:39:04 AM] : Activation of http://localhost:8080/geoserver24Aug/wfs?request=getCapabilities has started.
ERROR DETAILS
Following errors were detected during this operation.
* [2/09/2011 11:39:04 AM] System.Deployment.Application.InvalidDeploymentException (ManifestParse)
- Exception reading manifest from http://localhost:8080/geoserver24Aug/wfs?request=getCapabilities: the manifest may not be valid or the file could not be opened.
- Source: System.Deployment
- Stack trace:
at System.Deployment.Application.ManifestReader.FromDocument(String localPath, ManifestType manifestType, Uri sourceUri)
at System.Deployment.Application.DownloadManager.DownloadDeploymentManifestDirectBypass(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, SubscriptionState& subState, IDownloadNotification notification, DownloadOptions options, ServerInformation& serverInformation)
at System.Deployment.Application.DownloadManager.DownloadDeploymentManifestBypass(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, SubscriptionState& subState, IDownloadNotification notification, DownloadOptions options)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
--- Inner Exception ---
- Parsing and DOM creation of the manifest resulted in error. Following parsing errors were noticed:
Start line: 0
Start column: 0
Host file:
- Stack trace:
at System.Deployment.Application.Manifest.AssemblyManifest.LoadCMSFromStream(Stream stream)
at System.Deployment.Application.Manifest.AssemblyManifest..ctor(FileStream fileStream)
System.Runtime.InteropServices.COMException
- A device attached to the system is not functioning. (Exception from HRESULT: 0x8007001F)
- Stack trace:
at System.Deployment.Internal.Isolation.IsolationInterop.CreateCMSFromXml(Byte buffer, UInt32 bufferSize, IManifestParseErrorCallback Callback, Guid& riid)
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
