bbox ignored with Batik SVG producer backed by PostgisDataStore
Key: GEOS-475
URL: http://jira.codehaus.org/browse/GEOS-475
Project: GeoServer
Type: Bug
Components: WMS
Reporter: Justin Deoliveira
Assigned to: Justin Deoliveira
Fix For: 1.3.0 RC7
I have set WMS svg rendering to use Batik with styling.(you're right it is painfully slow) When I use the following url:
1582866 [FINE] org.geotools.data.jdbc.JDBC1DataStore - calling sql builder with filter Filter.NONE
1582876 [FINE] org.geotools.data.jdbc.JDBC1DataStore - sql is SELECT "oid", "name", "id", "state_prov", "country", "icao", "host_id", "loc_hdatum", "wgs_datum", "wgs_lat", "latitude", "wgs_long", "longitude", "elev", "type", "mag_var", "wac", "beacon", "arpt", "opr_agy", "sec_name", "sec_icao", "sec_faa", "opr_agy0", "cycle_date", AsText(force_2d("the_geom")) FROM "airports_icao" WHERE TRUE
The bbox intersect clause is left off? Curiously the text labels are clipped to the bbox but not the point symbols. Switching to the simple svg rendering gives the correct sql but won't render until http://jira.codehaus.org/browse/GEOS-457 is resolved.
1837693 [FINE] org.geotools.data.jdbc.JDBC1DataStore - calling sql builder with filter [ POLYGON ((-89 37, -89 42, -84 42, -84 37, -89 37)) intersects the_geom ]
1837693 [FINE] org.geotools.data.jdbc.JDBC1DataStore - sql is SELECT "oid", "name", "id", "state_prov", "country", "icao", "host_id", "loc_hdatum", "wgs_datum", "wgs_lat", "latitude", "wgs_long", "longitude", "elev", "type", "mag_var", "wac", "beacon", "arpt", "opr_agy", "sec_name", "sec_icao", "sec_faa", "opr_agy0", "cycle_date", AsText(force_2d("the_geom")) FROM "airports_icao" WHERE GeometryFromText('POLYGON ((-89 37, -89 42, -84 42, -84 37, -89 37))', 4269) && "the_geom" AND intersects(GeometryFromText('POLYGON ((-89 37, -89 42, -84 42, -84 37, -89 37))', 4269), "the_geom")
For more information on JIRA, see:
