[Geoserver-devel] [jira] Created: (GEOS-4766) Mods to CSS Documentation
                 Key: GEOS-4766
                 URL: https://jira.codehaus.org/browse/GEOS-4766
             Project: GeoServer
          Issue Type: Improvement
          Components: Documentation
    Affects Versions: 2.1.1
         Environment: All environments
            Reporter: David Collins
            Assignee: David Collins
            Priority: Minor
             Fix For: 2.1.2
Modify trunk CSS Styling documentation.
1. Mention that the style needs to be set in the Layer properties to the new CSS style - it is not assigned in the 'CSS Demo'.
2. Where necessary, split tables so that they are not more than one page long - else the bottom of the table is missing in the PDF documentation.
3. Possibly, add some information about anchoring labels.
4. Add a section for examples, and add an example where the markers' areas are proportional to an attribute value.
5. Some general editing.
