[Geoserver-devel] [jira] Created: (GEOS-4776) Can't select layer in Layer Groups if two layers have same name
                 Key: GEOS-4776
                 URL: https://jira.codehaus.org/browse/GEOS-4776
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 2.1.1
         Environment: Geoserver running on a Ubuntu 10.10
            Reporter: Victor Clogenson
            Assignee: Justin Deoliveira
            Priority: Minor
I have 2 stores, and one workspace in each, one for the real database, one for tests with another database, but same characteristics. As a result, each layer is present two times, one for the real, one for the test.
The problem came with the layer groups : when I select a layer from my test workspace, geoserver always use the one from the real workspace. Desactivate the real workspace do nothing. The only way I found is to rename a layer, make my group and rename back my layer.
