[Geoserver-devel] [jira] Created: (GEOS-4786) Edit Layer - Coordinate Reference Systems - Search facility does nothing
                 Key: GEOS-4786
                 URL: https://jira.codehaus.org/browse/GEOS-4786
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 2.1.1
         Environment: Windows XP Pro, Internet Explorer 8
            Reporter: Ron Goodman
            Assignee: Justin Deoliveira
Selecting the Edit Layer - Declared SRS - Find button - opens a multi-page Coordinate Systems list form. The search facility on this form appears to do nothing when text is entered into it. If carriage return is pressed after text entry a question dialog opens asking if you want to navigate away from this page. Yes closes both the list form and the edit layer page - No returns to the coordinate systems list but still unfiltered by the search entry. Tried multiple searches using strings and numbers such as Pinang, Cassini, Malay, 3382. The specific data source was a PostGIS database but a Shape file source showed the same problem
