[Geoserver-devel] [jira] Created: (GEOS-4809) i18n support for "UNKNOWN" native SRS in CRSPanel
                 Key: GEOS-4809
                 URL: https://jira.codehaus.org/browse/GEOS-4809
             Project: GeoServer
          Issue Type: Improvement
          Components: UI
    Affects Versions: 2.1.2, 2.2.x
            Reporter: Frank Gasdorf
            Assignee: Frank Gasdorf
            Priority: Minor
         Attachments: i18n-web-core-unknownSRS.patch
If the resource has no information about the SRS, the CRSPanel shows "UNKNOWN" in the srs text box, which is not editable.
The value "UNKNOWN" should be externalized to support translations
the patch makes an "unknownSRS" property available in the web-core module GeoServerApplication.properties file. A scan of text occurrence "UNKNOWN" shows up org.geoserver.catalog.rest.CoverageStoreFileResource. I guess its not relevant for the web (ui) but maybe there is a correlation I'm unaware of..
