Move capabilities/ schema information to top level directory
Key: GEOS-481
URL: http://jira.codehaus.org/browse/GEOS-481
Project: GeoServer
Type: Sub-task
Components: Configuration
Versions: 1.3.0 RC6
Reporter: Chris Holmes
Assigned to: Chris Holmes
Priority: Critical
Fix For: 1.3.0 RC7
A big problem with the first iteration of the data_dir was that the capabilities directory (which is mis-named), with the schemas, was in the data_dir, so that if the dir was not in the webapp, they wouldn't get referenced properly. This should move to its own directory, alongside data, and the guys who need it should call it directly. This should be easy to implement, since they already grab the location of that directory from a central place - util/Requests.java.
For more information on JIRA, see:
