[Geoserver-devel] [jira] Created: (GEOS-4857) PostGIS Layer Leaking Connection when using WMS getFeatureInfo calls in Layer Preview (Open Layers)
                 Key: GEOS-4857
                 URL: https://jira.codehaus.org/browse/GEOS-4857
             Project: GeoServer
          Issue Type: Bug
          Components: PostGIS
    Affects Versions: 2.1.3
         Environment: Ubuntu
            Reporter: Tony Na
            Assignee: Andrea Aime
In Layer Preview, open a OpenLayers preview of a PostGIS layer. Click on the map to get attributes of a single feature(each single click is a WMS getFeatureInfo call). After {max_connections} clicks, future calls would be blocked, including zooming of the map. When I check for active connections in PostGres, all connections are shown as "<Idle> in transaction". Click on "Free Locks" button in Server Status panel clears all the blocking connections. I suspect some result sets are not closed either in the OpenLayers code generated by Layer Preview, or in WMS getFeatureInfo calls.
Debug trace of timeout error attached:
21 Nov 14:32:02 ERROR [geotools.rendering] - Unable to obtain connection: Cannot get a connection, pool error Timeout waiting for idle object
java.lang.RuntimeException: Unable to obtain connection: Cannot get a connection, pool error Timeout waiting for idle object
  at org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:1635)
  at org.geotools.jdbc.JDBCDataStore.getConnection(JDBCDataStore.java:1584)
  at org.geotools.jdbc.JDBCDataStore.getConnection(JDBCDataStore.java:1614)
  at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:552)
  at org.geotools.jdbc.JDBCFeatureStore.getReaderInternal(JDBCFeatureStore.java:215)
  at org.geotools.data.store.ContentFeatureSource.getReader(ContentFeatureSource.java:496)
  at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:221)
  at org.geotools.data.store.ContentFeatureCollection.features(ContentFeatureCollection.java:64)
  at org.geotools.data.crs.ForceCoordinateSystemFeatureResults.openIterator(ForceCoordinateSystemFeatureResults.java:95)
  at org.geotools.feature.collection.AbstractFeatureCollection.iterator(AbstractFeatureCollection.java:343)
  at org.geotools.renderer.lite.StreamingRenderer.drawPlain(StreamingRenderer.java:2297)
  at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1982)
  at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:804)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:490)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:250)
  at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:125)
  at org.geoserver.wms.GetMap.executeInternal(GetMap.java:468)
  at org.geoserver.wms.GetMap.run(GetMap.java:208)
  at org.geoserver.wms.GetMap.run(GetMap.java:112)
  at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:353)
  at sun.reflect.GeneratedMethodAccessor238.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:309)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
  at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:60)
  at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:34)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
  at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:57)
  at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:39)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:54)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
  at $Proxy27.getMap(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor204.invoke(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:763)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:273)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:790)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:719)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:644)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:549)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
  at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
  at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
  at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
  at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
  at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:368)
  at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
  at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:380)
  at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:97)
  at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:78)
  at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:177)
  at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:79)
  at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:169)
  at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:237)
  at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:167)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
  at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
  at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
  at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
  at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
  at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
  at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
  at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
  at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
  at org.mortbay.jetty.Server.handle(Server.java:324)
  at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
  at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
  at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
  at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
  at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
  at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
  at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: org.apache.commons.dbcp.SQLNestedException: Cannot get a connection, pool error Timeout waiting for idle object
  at org.apache.commons.dbcp.PoolingDataSource.getConnection(PoolingDataSource.java:114)
  at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:1044)
  at org.geotools.data.jdbc.datasource.AbstractManageableDataSource.getConnection(AbstractManageableDataSource.java:46)
  at org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:1627)
  ... 99 more
Caused by: java.util.NoSuchElementException: Timeout waiting for idle object
  at org.apache.commons.pool.impl.GenericObjectPool.borrowObject(GenericObjectPool.java:1134)
  at org.apache.commons.dbcp.PoolingDataSource.getConnection(PoolingDataSource.java:106)
  ... 102 more
