[Geoserver-devel] [jira] Created: (GEOS-4865) NPE in WMS.getFeatureTypeTimes when feature has null time attribute
                 Key: GEOS-4865
                 URL: https://jira.codehaus.org/browse/GEOS-4865
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 2.1.2
            Reporter: Ian Schneider
            Assignee: Andrea Aime
         Attachments: fixWMSNPE.patch
The unique values computed by the UniqueVisitor include null in this case. This fails when adding the computed HashSet (can contain null) to a TreeSet (cannot contain nulls).
Attached (teeny) patch removes the null value from the unique set before adding.
As an aside, when looking at UniqueVisitor, it appears that null values are not added to the set (at least not in visit(Feature). In this case, the JDBCDataStore uses the setValue(Object) method that does not strip nulls from the resulting set. Recommend fixing the semantics of setValue though not sure what would break...
Of course, removing a null from a set invites breakage when someone decides the UniqueVisitor set implementation should be TreeSet. Perhaps another nice change would be to allow providing the set implementation for UniqueVisitor - this would also avoid the extra set copying that is occurring...
