Exception after changing data store to DB with different schema
Key: GEOS-4870
URL: https://jira.codehaus.org/browse/GEOS-4870
Project: GeoServer
Issue Type: Bug
Affects Versions: 2.1.2
Environment: Windows 7 x64, PostgreSQL 9.1.1, PostGIS 2.0.0
Reporter: Evan Martin
Assignee: Andrea Aime
I edited my PostGIS data store to point to a different database, one that has the same tables defined, but different column names. I then tried to edit the layer to update the column name in the SQL view, but clicking on the layer resulted in the following exception:
org.apache.wicket.WicketRuntimeException: java.io.IOException: Error occurred building feature type
at org.geoserver.web.data.resource.FeatureResourceConfigurationPanel$1.getObject(FeatureResourceConfigurationPanel.java:59)
at org.geoserver.web.data.resource.FeatureResourceConfigurationPanel$1.getObject(FeatureResourceConfigurationPanel.java:53)
at org.apache.wicket.Component.getDefaultModelObject(Component.java:1720)
at org.apache.wicket.markup.html.list.ListView.getViewSize(ListView.java:220)
at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:511)
at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:131)
at org.apache.wicket.Component.internalBeforeRender(Component.java:1071)
at org.apache.wicket.Component.beforeRender(Component.java:1105)
at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753)
at org.apache.wicket.Component.onBeforeRender(Component.java:3946)
at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:151)
at org.apache.wicket.extensions.markup.html.tabs.TabbedPanel.onBeforeRender(TabbedPanel.java:244)
at org.apache.wicket.markup.html.form.Form.onBeforeRender(Form.java:2056)
at org.apache.wicket.Page.onBeforeRender(Page.java:1531)
at org.apache.wicket.Component.prepareForRender(Component.java:2292)
at org.apache.wicket.Page.prepareForRender(Page.java:1521)
at org.apache.wicket.Component.prepareForRender(Component.java:2329)
at org.apache.wicket.Page.renderPage(Page.java:892)
at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.respond(BookmarkablePageRequestTarget.java:261)
at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:105)
at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1258)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:138)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.io.IOException: Error occurred building feature type
at org.geotools.jdbc.JDBCFeatureSource.buildFeatureType(JDBCFeatureSource.java:342)
at org.geotools.jdbc.JDBCDataStore.createFeatureSource(JDBCDataStore.java:768)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:385)
at org.geotools.data.store.ContentDataStore.getFeatureSource(ContentDataStore.java:350)
at org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:335)
at org.geotools.jdbc.JDBCDataStore.addVirtualTable(JDBCDataStore.java:278)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:625)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:588)
at org.geoserver.catalog.ResourcePool.loadAttributes(ResourcePool.java:471)
at org.geoserver.catalog.ResourcePool.getAttributes(ResourcePool.java:447)
at org.geoserver.web.data.resource.FeatureResourceConfigurationPanel$1.getObject(FeatureResourceConfigurationPanel.java:57)
... 129 more
Caused by: org.postgresql.util.PSQLException: ERROR: column s.geoserver_patches does not exist
Position: 62
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2062)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1795)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:479)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:353)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:252)
at org.apache.commons.dbcp.DelegatingStatement.executeQuery(DelegatingStatement.java:208)
at org.geotools.jdbc.JDBCFeatureSource.getColumnMetadata(JDBCFeatureSource.java:697)
at org.geotools.jdbc.JDBCFeatureSource.buildFeatureType(JDBCFeatureSource.java:196)
... 139 more
