GWC problem while using DB2 connection.
Key: GEOS-4873
URL: https://jira.codehaus.org/browse/GEOS-4873
Project: GeoServer
Issue Type: Bug
Components: DB2
Affects Versions: 2.1.1
Environment: OS: Ubuntu 9.10
Geoserver: 2.1.1
DB2: 9.7
Reporter: Neckie Chuang
Assignee: Andrea Aime
Hello,
The error msg shows up while doing GWC process...
Caused by: com.ibm.db2.jcc.am.SqlException: DB2 SQL Error: SQLCODE=-805, SQLSTATE=51002, SQLERRMC=NULLID.SYSLH203 0X5359534C564C3031, DRIVER=3.57.82
at com.ibm.db2.jcc.am.bd.a(bd.java:679)
at com.ibm.db2.jcc.am.bd.a(bd.java:60)
at com.ibm.db2.jcc.am.bd.a(bd.java:127)
at com.ibm.db2.jcc.am.km.c(km.java:2506)
at com.ibm.db2.jcc.t4.db.o(db.java:829)
at com.ibm.db2.jcc.t4.db.g(db.java:142)
at com.ibm.db2.jcc.t4.db.a(db.java:39)
at com.ibm.db2.jcc.t4.t.a(t.java:32)
at com.ibm.db2.jcc.t4.sb.h(sb.java:135)
at com.ibm.db2.jcc.am.km.eb(km.java:1934)
at com.ibm.db2.jcc.am.lm.ic(lm.java:2798)
at com.ibm.db2.jcc.am.lm.b(lm.java:3517)
at com.ibm.db2.jcc.am.lm.Vb(lm.java:654)
at com.ibm.db2.jcc.am.lm.executeQuery(lm.java:628)
at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)
at org.geotools.jdbc.JDBCFeatureReader.<init>(JDBCFeatureReader.java:163)
at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:551)
... 43 more
The error caused by the resources have been run out without any release.
Is anyone have any idea about this?
Thank you so much.
