[Geoserver-devel] [jira] Created: (GEOS-4886) GeoWebCache does not return the correct tiles for an extent when using a gridset created for EPSG:3031
                 Key: GEOS-4886
                 URL: https://jira.codehaus.org/browse/GEOS-4886
             Project: GeoServer
          Issue Type: Bug
          Components: GWC
    Affects Versions: 2.1.2
         Environment: Running GeoWebCache as part of GeoServer.
            Reporter: Brendan Barrett
            Assignee: Andrea Aime
            Priority: Critical
         Attachments: GeoWebCacheBug_Files.zip
I created a WMS server to host LIMA data (Landsat Imagery Mosaic of Antarctica). You can find the original imagery as a GeoTiff here: http://lima.usgs.gov/tiff_90pct.zip.
I set up the Layer (specifying EPSG:3031), and when I preview using Layer Preview it displays exactly as expected, and I can overlay KML data over it in OpenLayers. This means that the coordinates are correct.
I then need to set up a gridset to be able to use this layer with GeoWebCache so that it knows what bounds to create the tiles between. I attached the geowebcache.xml file in the zip file attached to this bug report.
When I view the map again, using geowebcache, I get strange results. Each layer that I zoom into starts with a rendering of the first tile of the layer, and then each tile after that looks exactly the same. See the two attached screen grabs in the zip file to see what I am talking about.
The tiles are stored exactly like this in the cache folder too.
If I change the values for extents, or specify resolutions in the gridset, I get the same result.
My conclusion is that geowebcache cannot handle EPSG:3031.
I have marked the issue as critical... as it is for those of us that need to view data in EPSG:3031, which is basically anyone looking at Antarctic data.
