[Geoserver-devel] [jira] Created: (GEOS-4890) Error rendering coverage on the fast path
                 Key: GEOS-4890
                 URL: https://jira.codehaus.org/browse/GEOS-4890
             Project: GeoServer
          Issue Type: Bug
            Reporter: Gabriel Roldán
            Assignee: Andrea Aime
I'm getting the bellow exception when executing a GetMap request like
the following on both 2.1.x and trunk:
[http://localhost:8080/geoserver/wms?LAYERS=nurc%3AArc_Sample&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=1335507.7609878,-1574602.7798854,1336119.2572141,-1573991.2836591&WIDTH=256&HEIGHT=256]
Data directory is the release one, layer nurc:Arc_Sample.
I'm on linux, java is
java version "1.6.0_26"
Java(TM) SE Runtime Environment (build 1.6.0_26-b03)
Java HotSpot(TM) 64-Bit Server VM (build 20.1-b02, mixed mode)
It happens with both native JAI/ImageIO installed and not.
