[Geoserver-devel] [jira] Created: (GEOS-49) sql
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-49
Here is an overview of the issue:
        Key: GEOS-49
    Summary: sql
       Type: Bug
     Status: Open
   Priority: Major
Original Estimate: 30 minutes
Time Spent: Unknown
  Remaining: 30 minutes
    Project: GeoServer
Components:
             Global
   Fix Fors:
             1.2
   Versions:
             1.2
   Assignee: Chris Holmes
   Reporter: David Zwiers
    Created: Fri, 16 Jan 2004 5:45 PM
    Updated: Fri, 16 Jan 2004 5:45 PM
Description:
Can you tell me how FeatureTypeTransformer must be changed/improved so that it is "in good enough shape" for cite. What is missing? I might look into this and improve FeatureTypeTransformer. Or is it just the problem that FeatureType and AttributeType do not provide enough information?
Simon
Am 16.01.2004 um 21:24 schrieb Chris Holmes:
Will you put this as a bug in JIRA? Also for the cite tests you should
use schema.xml files, there's no way the FeatureTypeTransformer is in good
enough shape to handle cite. The featureTypes that you need are defined
in the misc/cite/citeTypes.tar.gz, just unzip it and it will build the
featureType structure that you need.
Chris
On Fri, 16 Jan 2004, David Zwiers wrote:
My response.
<wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:cdf="http://www.opengis.net/cite/data&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/wfs http://office.refractions.net:8081/geoserver/wfs/1.0.0/WFS-basic.xsd http://www.opengis.net/cite/data http://office.refractions.net:8081/geoserver/wfs/DescribeFeatureType? typeName=cdf:Other">
  <gml:boundedBy>
    <gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#32118&quot;&gt;
      <gml:coordinates decimal="." cs="," ts=" ">500000,500000 500000,500100 500100,500100 500100,500000</gml:coordinates>
    </gml:Box>
  </gml:boundedBy>
  <gml:featureMember>
    <cdf:Other fid="Other.676316386">
      <cdf:gmldescription>A Single Feature used to test returning of properties</cdf:gmldescription>
      <cdf:gmlname>singleFeature</cdf:gmlname>
      <gml:boundedBy>
        </gml:Box>
      </gml:boundedBy>
      <gml:pointProperty>
        <gml:Point srsName="http://www.opengis.net/gml/srs/epsg.xml#32118&quot;&gt;
          <gml:coordinates decimal="." cs="," ts=" ">500050,500050</gml:coordinates>
        </gml:Point>
      </gml:pointProperty>
      <cdf:string1>always</cdf:string1>
      <cdf:string2>sometimes</cdf:string2>
      <cdf:integers>7</cdf:integers>
      <cdf:dates>2002-12-02</cdf:dates>
    </cdf:Other>
  </gml:featureMember>
</wfs:FeatureCollection>
The buged lines of this:
This should read:
      <gml:description>A Single Feature used to test returning of properties</cdf:gmldescription>
      <gml:name>singleFeature</cdf:gmlname>
The problem has to do with extracting these from the database ...
The Other table is defined as:
              Table "public.Other"
     Column | Type | Modifiers
gmldescription | character varying |
gmlname | character varying |
boundedBy | geometry |
pointProperty | geometry |
string1 | character varying | not null
string2 | character varying |
integers | integer |
dates | date |
Check constraints: "$1" (srid("pointProperty") = 32615)
                   "$2" ((geometrytype("pointProperty") = 'POINT'::text)
OR ("pointProperty" IS NULL))
                   "$3" (srid("boundedBy") = 32615)
                   "$4" ((geometrytype("boundedBy") = 'POLYGON'::text)
OR ("boundedBy" IS NULL))
David
The SF.Net email is sponsored by EclipseCon 2004
Premiere Conference on Open Tools Development and Integration
See the breadth of Eclipse activity. February 3-5 in Anaheim, CA.
http://www.eclipsecon.org/osdn
Geoserver-devel mailing list
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
