Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-5
Here is an overview of the issue:
Key: GEOS-5
Summary: Throw friendly exception if a request is made while the server did not finished its startup process
Type: Task
Status: Open
Priority: Minor
Original Estimate: 30 minutes
Time Spent: Unknown
Remaining: 30 minutes
Project: GeoServer
Components:
Error Reporting
Versions:
wms-merge
Assignee: Chris Holmes
Reporter: Gabriel Rold?n
Created: Wed, 19 Nov 2003 2:29 AM
Updated: Wed, 19 Nov 2003 2:29 AM
Description:
While the servlet engine can be ready to accept user requests, it is possible that a request is made while the geoserver startup process was not finished yet, mostly probable due to de delay added by the set up of DataStores.
In such case, geoserver should be able to send an exception instead of just failing and get the servlet container disabling the called servlet.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
