[Geoserver-devel] [jira] Created: (GEOS-503) SRS in FeatureTypeEditor
         Key: GEOS-503
         URL: http://jira.codehaus.org/browse/GEOS-503
     Project: GeoServer
        Type: Improvement
    Reporter: dblasby
Assigned to: dblasby
     Fix For: 1.3.0
A user reported having problems when adding data in a projection that required TOWSG (bursa wolfe parameters) to get it to WSG84 (the standard lat/long bounding box projection).
Geoserver should be reporting an error. Unforunately, errors are all hidden on the left hand column (and are not internationalized).
Since this error is causing problems, we should make have a page-or-something that explains whats happening and what to do about it. We could also allow them to turn off the strict SRS xform stuff as a config parameter so it unlikely to actually have an error.
Also, try out using the EPSG HSQL database instead of the WKT version. NOTE: the EPSG database may have the 4326 (standard WSG84 project) rotated 90 degrees. It should be obvious if it is.
For more information on JIRA, see:
