[Geoserver-devel] [jira] Created: (GEOS-504) Encoding bug for Japanese localization
         Key: GEOS-504
         URL: http://jira.codehaus.org/browse/GEOS-504
     Project: GeoServer
        Type: Bug
  Components: Struts
    Versions: 1.3.0 RC6
Environment: Win2000
    Reporter: Akira Sugawara
Assigned to: dblasby
I reported yet that by only translating messeage properties file the geoserver's page was not displayied in japanease at GEOS-498 "Japanese localization", but I found this cause at last.
A cause is because a description to appoint encoding fell out in JSP source file.
Adding <%@ page contentType="text/html; charset=UTF-8" %> to a source of jsp, Japanese was displayed justly.
A single byte letter code such as English is displayed adequately by iso-8859-1 without encoding instructions, but clear encode instructions are necessary for multi-byte language such as Japanese .
It is not displayed justly only by using charset=UTF-8 in a meta tag.
There is charset=iso-8859-1 on a source of jsp, but I thinks that it should be change in charset=UTF-8.
I am examining and checking with the japanese property file that I transrated.
If an examination was finished, I will donate a Japanese property file and patch to community.
For more information on JIRA, see:
That's good news that you have traced down the problem Akira. When you are ready with a patch, please submit it to us and we will apply it.
Brent Owens
TOPP
        Key: GEOS-504
    Project: GeoServer
       Type: Bug
Components: Struts Versions: 1.3.0 RC6 Environment: Win2000
A cause is because a description to appoint encoding fell out in JSP source file. Adding <%@ page contentType="text/html; charset=UTF-8" %> to a source of jsp, Japanese was displayed justly.
It is not displayed justly only by using charset=UTF-8 in a meta tag. There is charset=iso-8859-1 on a source of jsp, but I thinks that it should be change in charset=UTF-8.
I am examining and checking with the japanese property file that I transrated. If an examination was finished, I will donate a Japanese property file and patch to community.
