Column of type float in Oracle is not included in schema when adding FeatureType
Key: GEOS-505
URL: http://jira.codehaus.org/browse/GEOS-505
Project: GeoServer
Type: Bug
Components: Oracle, Configuration
Versions: 1.3.0 RC6
Reporter: Aksel Hilde
Assigned to: dblasby
Fix For: 1.3.0 RC7
I am adding a new feature based on an oracle view that includes a column of type FLOAT. This is not included in the list of attributes mapped for the feature. Tried using the schema type gml:AbstractFeatureType, and edit the schema.xml file manually to add the element, but that caused Geoserver to not being able to load the feature config.
For more information on JIRA, see:
