[Geoserver-devel] [jira] Created: (GEOS-52) Save XML button does not work.
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-52
Here is an overview of the issue:
        Key: GEOS-52
    Summary: Save XML button does not work.
       Type: Bug
     Status: Open
   Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
Components:
             Configuration
   Assignee: Chris Holmes
   Reporter: Richard Gould
    Created: Fri, 16 Jan 2004 8:31 PM
    Updated: Fri, 16 Jan 2004 8:31 PM
Description:
java.lang.NullPointerException
  at org.vfny.geoserver.global.xml.WriterHelper.openTag(WriterHelper.java:129)
  at org.vfny.geoserver.global.xml.XMLConfigWriter.storeFeatureSchema(XMLConfigWriter.java:533)
  at org.vfny.geoserver.global.xml.XMLConfigWriter.storeFeatureSchema(XMLConfigWriter.java:523)
  at org.vfny.geoserver.global.xml.XMLConfigWriter.storeFeatures(XMLConfigWriter.java:440)
  at org.vfny.geoserver.global.xml.XMLConfigWriter.store(XMLConfigWriter.java:86)
  at org.vfny.geoserver.global.xml.XMLConfigWriter.store(XMLConfigWriter.java:107)
  at org.vfny.geoserver.action.SaveXMLAction.execute(SaveXMLAction.java:41)
  at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:484)
  at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:274)
  at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1482)
  at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:525)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:165)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:103)
  at com.caucho.server.dispatch.ServletFilterChain.doFilter(ServletFilterChain.java:113)
  at com.caucho.server.cache.CacheFilterChain.doFilter(CacheFilterChain.java:190)
  at com.caucho.server.webapp.WebAppFilterChain.doFilter(WebAppFilterChain.java:177)
  at com.caucho.server.dispatch.ServletInvocation.service(ServletInvocation.java:221)
  at com.caucho.server.http.HttpRequest.handleRequest(HttpRequest.java:253)
  at com.caucho.server.port.TcpConnection.run(TcpConnection.java:305)
  at com.caucho.util.ThreadPool.run(ThreadPool.java:273)
  at java.lang.Thread.run(Thread.java:534)
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
