side bar on downloaded docs is always in the middle
Key: GEOS-524
URL: http://jira.codehaus.org/browse/GEOS-524
Project: GeoServer
Type: Improvement
Components: Documentation
Versions: 1.3.0 PR1
Reporter: Chris Holmes
Assigned to: Justin Deoliveira
Priority: Trivial
Fix For: 1.3.0
This is again super anal. But I don't like how the nav bar on the downloaded docs acts. It seems to not be like a normal nav bar, just on the frame, but instead to be a part of each page. Which would be ok if it was always in the same place. But it's in the middle of each page, meaning it moves up and down, if the page is long.
I'd like to see a real nav bar, like the way the old docs worked, with a navigation.html and a index.html that frames the navigation with the doc being viewed.
You guys can choose not to do this bug fix if you'd like, it's just me getting super anal.
The other thing in general I'd like to see is better top level overviews of what all is in the docs. The Documentation Tree helps for this, and I did something like it for the User page. But when I start on the docs I find it a bit unclear where to start. I think this may be an artefact of translating from wiki -> a more linear format, but I'm not sure. I think we may just need more overviews...
For more information on JIRA, see:
