can't alter data in the mapnuilder demo - php problem?
Key: GEOS-528
URL: http://jira.codehaus.org/browse/GEOS-528
Project: GeoServer
Type: Task
Components: Mapbuilder Intergration
Versions: 1.3.0 RC5
Environment: Windows XP
Reporter: Chris Ewing
Assigned to: dblasby
Priority: Minor
Attachments: error.png
Bear with me as I'm new to this and trying to work out how to set up a simple MapBuilder site using data I have loaded onto GeoServer.
I have the mapbuilder demo working with the simple and wfs-t demos.
The simple demo (http://localhost:8080/geoserver/mapbuilder/demo/simple/index.html) works ok and seems to access the simpleConfig.xml file. This in turns should go to the ../data/context/atlasWorld.xml file specified in defaultModelUrl.
This works fine.
I am then trying to change the data source for the maps. And I'm getting pretty stuck!
In the simpleConfig file the 3rd line says xsi:schemaLocation="http://mapbuilder.sourceforge.net/mapbuilder ../../lib/schemas/config.xsd">
Does this mean that the schema is being pulled from http://mapbuilder.sourceforge.net/mapbuilder ?
If so I then change to look at my schema on localhost:8080
Does anyone have a brief overview of adding data to the simple MapBuilder map? Which xml files do I need to change? Do I need to have any PHP server running? I get this message (see attachment) when I try to change the URLs to look at my data.
I have had a good look round geoserver and the mapbuilder sites and I can't find anything!
Hope you can help.
Thanks
Chris
For more information on JIRA, see:
