NullPointerException in GeoserverDataDirectory when data directory is packaged in the WAR
Key: GEOS-531
URL: http://jira.codehaus.org/browse/GEOS-531
Project: GeoServer
Type: Bug
Components: Configuration
Versions: 1.3.0 PR1
Environment: Windows XP, Java 1.5, Jetty or WebLogic 9.1 container
Reporter: Aksel Hilde
Assigned to: dblasby
Priority: Blocker
Fix For: 1.3.0
The problem seems to be that GeoserverDataDirectory only handles the default data directory when geoserver is deployed as a flat directory in the web container. Naturally this bug occours when GEOSERVER_DATA_DIR is not used. Then line 89-90 in GeoserverDataDirectory handles the job of creating a file referanse to the data dir:
String rootDir = servContext.getRealPath("/");
dataDir = new File (rootDir);
The NullPointer happens in the File constructor because servContext.getRealPath("/") return null when the web app is packaged in a WAR, as is also documented in the JEE api docs.
BTW: Using the GEOSERVER_DATA_DIR is not really wanted in my production environment because we want to deploy both the geoserver version and the data directory stuff together with our other ear/war deployment.
For more information on JIRA, see:
