Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-54
Here is an overview of the issue:
Key: GEOS-54
Summary: Load XML button does not work.
Type: Bug
Status: Open
Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
Remaining: Unknown
Project: GeoServer
Components:
Configuration
Assignee: Chris Holmes
Reporter: Richard Gould
Created: Fri, 16 Jan 2004 8:32 PM
Updated: Fri, 16 Jan 2004 8:32 PM
Description:
java.lang.NullPointerException
at org.vfny.geoserver.global.xml.XMLConfigReader.getKeyWords(XMLConfigReader.java:956)
at org.vfny.geoserver.global.xml.XMLConfigReader.loadFeaturePt2(XMLConfigReader.java:914)
at org.vfny.geoserver.global.xml.XMLConfigReader.loadFeature(XMLConfigReader.java:865)
at org.vfny.geoserver.global.xml.XMLConfigReader.loadFeatureTypes(XMLConfigReader.java:791)
at org.vfny.geoserver.global.xml.XMLConfigReader.loadCatalog(XMLConfigReader.java:255)
at org.vfny.geoserver.global.xml.XMLConfigReader.load(XMLConfigReader.java:163)
at org.vfny.geoserver.global.xml.XMLConfigReader.<init>(XMLConfigReader.java:131)
at org.vfny.geoserver.action.LoadXMLAction.execute(LoadXMLAction.java:42)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:484)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:274)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1482)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:525)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:165)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:103)
at com.caucho.server.dispatch.ServletFilterChain.doFilter(ServletFilterChain.java:113)
at com.caucho.server.cache.CacheFilterChain.doFilter(CacheFilterChain.java:190)
at com.caucho.server.webapp.WebAppFilterChain.doFilter(WebAppFilterChain.java:177)
at com.caucho.server.dispatch.ServletInvocation.service(ServletInvocation.java:221)
at com.caucho.server.http.HttpRequest.handleRequest(HttpRequest.java:253)
at com.caucho.server.port.TcpConnection.run(TcpConnection.java:305)
at com.caucho.util.ThreadPool.run(ThreadPool.java:273)
at java.lang.Thread.run(Thread.java:534)
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
