[Geoserver-devel] [jira] Created: (GEOS-547) TransactionResponse problem
         Key: GEOS-547
         URL: http://jira.codehaus.org/browse/GEOS-547
     Project: GeoServer
        Type: Bug
    Reporter: dblasby
Assigned to: dblasby
     Fix For: 1.3.1
NOTE: first thing to do on the transaction reponse is to re-factor the code so its easy to understand (and not 800 lines long).
From jody (to track this issue):
I am writing up an article on TransactionResponse ... and I think I found a bug:
We start with an modifyFeatures - processing update elemet here:
                       if (types.length == 1) {
                           store.modifyFeatures(types[0], values[0], filter);
                       } else {
                           store.modifyFeatures(types, values, filter);
Then we try and unlock the stuff that was justed changed:
                   if ((request.getLockId() != null)
                           && store instanceof FeatureLocking
                           && (request.getReleaseAction() == TransactionRequest.SOME)) {
                       FeatureLocking locking = (FeatureLocking) store;
                       locking.unLockFeatures(filter);
Problem is we *just* changed the content, so that filter is not going to return the same set of features.
All is not lost, ealier we preprocessed the filter into a set of fids and bounding box. I think we could modify the code to operate with a new Filter constructed out of the Fid Set....
Jody
For more information on JIRA, see:
