Null pointer if edit, default, or delete on empty namespace
Key: GEOS-551
URL: http://jira.codehaus.org/browse/GEOS-551
Project: GeoServer
Type: Sub-task
Reporter: Brent Owens
Assigned to: dblasby
Priority: Critical
Fix For: 1.3.1
if a user presses the delete, edit, or default button on the namespace screen when there are no namespaces specified, the following NullPointerException is thrown:
java.lang.NullPointerException
at org.vfny.geoserver.action.data.DataNamespacesSelectAction.execute(DataNamespacesSelectAction.java:58)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:98)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:484)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:274)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1482)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:525)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:760)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:122)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
at jrun.servlet.FilterChain.service(FilterChain.java:101)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:259)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:541)
at jrun.servlet.http.WebService.invokeRunnable(WebService.java:172)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
javax.servlet.ServletException
at org.apache.struts.action.RequestProcessor.processException(RequestProcessor.java:545)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:486)
For more information on JIRA, see:
