[Geoserver-devel] [jira] Created: (GEOS-555) GML3.1.1 output support
         Key: GEOS-555
         URL: http://jira.codehaus.org/browse/GEOS-555
     Project: GeoServer
        Type: Sub-task
    Reporter: Jody Garnett
Assigned to: Justin Deoliveira
    Priority: Critical
The community schema output is defined in terms of GML3.1.1, we need to formalize our GML3.1.1 technology and code this up.
There are two choices:
1. Making use of the GTXML (aka schema assied parsing) bindings, and using them for printing
2. Using the existing XML Tranformer technology in geotools, that I think Gabriel has extended already?
Justin - I know you have requested a review of your xml generation APIs, I still have more normal requirement (XML schema is a program, we should not have to code anything in Java that has already been writenin XML schema). Now we cannot get 100%, for WFS both GML3 and WFS define something that can capture a FeatureCollection - let the user choose, or choose the longest" chain. You can also review the existing XDO printing bindings for inspiration.
For those following at home:
- http://udig.refractions.net/confluence/display/OWS3/GTXML+Article
Justin if you do not have enough time to figure this one, please check if Gabriel would be willing to maintain his existing GML3 generation code a bit longer.
I have given this the default 2 week estimate, please adjust to reflect your experience.
For more information on JIRA, see:
