[Geoserver-devel] [jira] Created: (GEOS-559) Community Schema Config User Interface
         Key: GEOS-559
         URL: http://jira.codehaus.org/browse/GEOS-559
     Project: GeoServer
        Type: Sub-task
    Reporter: Jody Garnett
Assigned to: Justin Deoliveira
Hi Justin you once again get the nod - You know enough spring so you will need an excuse to teach everyone what a Spring based user interface looks like.
It is up to you if you want to maintain the DTO abstraction to seperate out the configuration application from the live running geoserver. You know my thoughts with resepect to the overhead...
As an alternative, this may be as easy as adding and additional button to the individual attributes defined in the FeatureType screen, one that lets you define the attribute as a "join expression". Give it enough knowledge about external keys and this could be as easy as choosing from a list, with the last entry as custom.
For more information on JIRA, see:
