Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-56
Here is an overview of the issue:
Key: GEOS-56
Summary: The embedded Tomcat no longer works.
Type: Bug
Status: Open
Priority: Critical
Original Estimate: Unknown
Time Spent: Unknown
Remaining: Unknown
Project: GeoServer
Assignee: Chris Holmes
Reporter: Chris Holmes
Created: Sat, 17 Jan 2004 4:51 PM
Updated: Sat, 17 Jan 2004 4:51 PM
Description:
The embedded tomcat - started by the 'ant test' target - no longer works. Most likely the jars just need to be updated in some way, or the build.xml file needs to copy some files over correctly. The current error is:
] StandardContext: Servlet threw load() exception
[java] javax.servlet.ServletException: Servlet.init() for servlet action threw exception
[java] at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:935)
[java] at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:808)
[java] at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:3266)
[java] at org.apache.catalina.core.StandardContext.start(StandardContext.java:3395)
[java] at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1123)
[java] at org.apache.catalina.core.StandardHost.start(StandardHost.java:614)
[java] at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:343)
[java] at org.apache.catalina.startup.Embedded.start(Embedded.java:957)
[java] at org.vfny.geoserver.EmbeddedTomcat.startTomcat(EmbeddedTomcat.java:133)
[java] at org.vfny.geoserver.EmbeddedTomcat.main(EmbeddedTomcat.java:285)
[java] ----- Root Cause -----
[java] java.lang.NullPointerException
[java] at org.apache.struts.action.ActionServlet.parseModuleConfigFile(ActionServlet.java:1003)
[java] at org.apache.struts.action.ActionServlet.initModuleConfig(ActionServlet.java:955)
[java] at org.apache.struts.action.ActionServlet.init(ActionServlet.java:470)
[java] at javax.servlet.GenericServlet.init(GenericServlet.java:258)
[java] at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:916)
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
