WFS 1.1 to support GML 3.1.1 syntax via Filter 1.1
Key: GEOS-564
URL: http://jira.codehaus.org/browse/GEOS-564
Project: GeoServer
Type: Sub-task
Reporter: Jody Garnett
Assigned to: Justin Deoliveira
This work brings together several ideas:
- GTXML based GML3.1.1 parsing (currently Point is bound)
- GTXML based Filter 1.1 parsing (bindings exist, test cases could be better)
- the research at http://udig.refractions.net/confluence/display/HACK/Home into what WFS 1.1 does that is new
I am not providing an intial estimate here, as that is covered a bit better on the above website. This task should be broken down and assiged out in chunks.
The biz goal is to allow queries against community schema using the same GML3 geometry as is represented by the datastores.
Although this is a simple "biz case" because of the nature of XMLSchema we cannot do this request half way:
- GetCapabilities is needed (showing GML3 as a format)
- DescribeFeatureType is needed (producing a GML3 based schema)
- GetFeatures is needed (making use of Filter 1.1 (and thus GML3.1.1))
Justin has done his job and provide us with a framework where additional modules can be dropped in to capture WFS 1.1 requests.
For more information on JIRA, see:
