[Geoserver-devel] [jira] Created: (GEOS-568) Applying a WFS datastore causes NullPointerException
         Key: GEOS-568
         URL: http://jira.codehaus.org/browse/GEOS-568
     Project: GeoServer
        Type: Sub-task
    Reporter: Brent Owens
Assigned to: Brent Owens
    Priority: Critical
     Fix For: 1.3.1
When hitting 'Apply' after you have created a new feature type that is on a WFS data store, a null pointer exception is thrown:
org.vfny.geoserver.wfs.WfsException: java.util.NoSuchElementException: Could not locate FeatureTypeConfig 'topp:states'
  at org.vfny.geoserver.wfs.WfsExceptionHandler.newServiceException(WfsExceptionHandler.java:65)
  at org.vfny.geoserver.servlets.AbstractService.sendError(AbstractService.java:749)
  at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:461)
  at org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:276)
  at org.vfny.geoserver.wfs.servlets.WfsDispatcher.doResponse(WfsDispatcher.java:284)
  at org.vfny.geoserver.wfs.servlets.WfsDispatcher.doGet(WfsDispatcher.java:213)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
  at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:358)
  at org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:342)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:122)
  at org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:334)
  at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:286)
  at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:567)
  at org.mortbay.http.HttpContext.handle(HttpContext.java:1807)
  at org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplicationContext.java:525)
  at org.mortbay.http.HttpContext.handle(HttpContext.java:1757)
  at org.mortbay.http.HttpServer.service(HttpServer.java:879)
  at org.mortbay.http.HttpConnection.service(HttpConnection.java:790)
  at org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:961)
  at org.mortbay.http.HttpConnection.handle(HttpConnection.java:807)
  at org.mortbay.http.SocketListener.handleConnection(SocketListener.java:197)
  at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:276)
  at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:511)
Caused by: java.util.NoSuchElementException: Could not locate FeatureTypeConfig 'topp:states'
  at org.vfny.geoserver.global.Data.getFeatureTypeInfo(Data.java:850)
  at org.vfny.geoserver.wfs.responses.DescribeResponse.getPrefix(DescribeResponse.java:503)
  at org.vfny.geoserver.wfs.responses.DescribeResponse.allSameType(DescribeResponse.java:477)
  at org.vfny.geoserver.wfs.responses.DescribeResponse.generateTypes(DescribeResponse.java:173)
  at org.vfny.geoserver.wfs.responses.DescribeResponse.execute(DescribeResponse.java:97)
  at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:449)
  ... 21 more
Feb 22, 2006 2:48:51 PM org.geotools.xml.handlers.xsi.RootHandler getHandler
WARNING: Starting schema with ServiceExceptionReport element.
java.lang.NullPointerException
  at org.geotools.data.wfs.WFSDataStore.getSchemaGet(WFSDataStore.java:392)
  at org.geotools.data.wfs.WFSDataStore.getSchema(WFSDataStore.java:293)
  at org.vfny.geoserver.global.Data.loadFeatureTypes(Data.java:345)
  at org.vfny.geoserver.global.Data.load(Data.java:154)
  at org.vfny.geoserver.action.UpdateGSAction.updateGeoserver(UpdateGSAction.java:71)
  at org.vfny.geoserver.action.UpdateGSAction.execute(UpdateGSAction.java:48)
  at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:98)
  at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:484)
  at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:274)
  at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1482)
  at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:525)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:760)
This has only been tested when the WFS datastore is on the same server (it is hitting itself).
For more information on JIRA, see:
