[Geoserver-devel] [jira] Created: (GEOS-57) Better error reporting when schema.xml has wrong attributes.
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-57
Here is an overview of the issue:
        Key: GEOS-57
    Summary: Better error reporting when schema.xml has wrong attributes.
       Type: Improvement
     Status: Open
   Priority: Major
Original Estimate: Unknown
Time Spent: Unknown
  Remaining: Unknown
    Project: GeoServer
Components:
             Configuration
             Error Reporting
   Fix Fors:
             1.2
   Versions:
             1.2
   Assignee: Chris Holmes
   Reporter: Chris Holmes
    Created: Sat, 17 Jan 2004 9:28 PM
    Updated: Sat, 17 Jan 2004 9:28 PM
Description:
I meant to get to this today, but if someone specifies a schema.xml file whose attributes don't _exactly_ match the names of the backend database the server fails very miserable, during getFeature requests. And very cryptically as well. So the reType function in FeatureTypeInfo should throw much more informative errors, with information as to what was read wrong, what was expected, how to fix the problem, ect. If anyone wants to take this go for it, it's pretty easy (and should be done soon, because it's only gonna cause others pain). If not I'll try to get it in monday or tuesday.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
