Cannot set type to Date
Key: GEOS-571
URL: http://jira.codehaus.org/browse/GEOS-571
Project: GeoServer
Type: Bug
Components: Configuration
Versions: 1.3.0 RC7
Environment: Win XP
Reporter: Amr A. Alam
Assigned to: dblasby
Priority: Critical
Setting up WFS backed by a postgis DB.
I have a column of type date in postgis. In geoserver, this shows up as dateTime by default; that's fine, but when I change it to 'date' (which is an available option) the feature type description doesn't seem to be affected at all!
this is what i get for that attribute regardless of whether i've picked 'date' or 'dateTime'.
<xs:element name="creationdate" minOccurs="0" nillable="true" type="xs:dateTime"/>
This basically makes it impossible to upload to (using geotools) if the date field is set to anything.
For more information on JIRA, see:
