[Geoserver-devel] [jira] Created: (GEOS-582) Exception Thrown when starting Geoserver
         Key: GEOS-582
         URL: http://jira.codehaus.org/browse/GEOS-582
     Project: GeoServer
        Type: Bug
  Components: Configuration
    Versions: 1.4.M0
Environment: Windows XP, Apache Tomcat/5.0.28, maven v. 1.0.2
    Reporter: Clint
Assigned to: dblasby
Hi, I want to build 1.4.x and publish the release but I cant do that just yet because when I start geoserver I get a stacktrace. What I did?
1: Got lastest changes from svn://svn.codehaus.org/geoserver/scm/branches/1.4.x
2: maven build, deployAll
3: copied target\geoserver.war into tomcat\webapps
4: started tomcat (startup.bat)
5: Threw the exception below
SEVERE: Parse Error at line 45 column 15: The content of element type "formset"
is incomplete, it must match "(constant*,form+)".
org.xml.sax.SAXParseException: The content of element type "formset" is incomple
        at org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseException(Un
known Source)
        at org.apache.xerces.util.ErrorHandlerWrapper.error(Unknown Source)
        at org.apache.xerces.impl.XMLErrorReporter.reportError(Unknown Source)
        at org.apache.xerces.impl.dtd.XMLDTDValidator.handleEndElement(Unknown S
ource)
        at org.apache.xerces.impl.dtd.XMLDTDValidator.endElement(Unknown Source)
        at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknow
n Source)
        at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContent
Dispatcher.dispatch(Unknown Source)
        at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Un
known Source)
        at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
        at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
        at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
        at org.apache.commons.digester.Digester.parse(Digester.java:1666)
        at org.apache.commons.validator.ValidatorResources.<init>(ValidatorResou
rces.java:159)
        at org.apache.struts.validator.ValidatorPlugIn.initResources(ValidatorPl
ugIn.java:237)
        at org.apache.struts.validator.ValidatorPlugIn.init(ValidatorPlugIn.java
:162)
        at org.apache.struts.action.ActionServlet.initModulePlugIns(ActionServle
t.java:869)
        at org.apache.struts.action.ActionServlet.init(ActionServlet.java:336)
        at javax.servlet.GenericServlet.init(GenericServlet.java:211)
        at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.
java:1029)
        at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:86
2)
        at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContex
t.java:4013)
        at org.apache.catalina.core.StandardContext.start(StandardContext.java:4
357)
        at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase
.java:823)
        at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:80
7)
        at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:595)
        at org.apache.catalina.core.StandardHostDeployer.install(StandardHostDep
loyer.java:277)
        at org.apache.catalina.core.StandardHost.install(StandardHost.java:832)
        at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:625
        at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:431
        at org.apache.catalina.startup.HostConfig.start(HostConfig.java:983)
        at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java
:349)
        at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(Lifecycl
eSupport.java:119)
        at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1091)
        at org.apache.catalina.core.StandardHost.start(StandardHost.java:789)
        at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1083)
        at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:478
        at org.apache.catalina.core.StandardService.start(StandardService.java:4
80)
        at org.apache.catalina.core.StandardServer.start(StandardServer.java:231
3)
        at org.apache.catalina.startup.Catalina.start(Catalina.java:556)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
        at java.lang.reflect.Method.invoke(Method.java:324)
        at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:287)
        at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:425)
16 [CONFIG] org.vfny.geoserver.global.xml.XMLConfigReader - logging level is CO
NFIG
For more information on JIRA, see:
