[Geoserver-devel] [jira] Created: (GEOS-583) cuncurrent WFS-requests are causing wrong responses
         Key: GEOS-583
         URL: http://jira.codehaus.org/browse/GEOS-583
     Project: GeoServer
        Type: Bug
  Components: WFS
    Versions: 1.3.0
Environment: All
    Reporter: Markus Wenzel
Assigned to: dblasby
    Priority: Blocker
     Fix For: 1.3.0
Attachments: patch.txt
If a client is sending more than one WFS GetFeature request concurrently (via 2 ore more threads) the resulting responses are sometimes mixed up: The city-request gets the river-response.
This is because the request is written to a temporary file by the WfsDispatcher and the file objekt is kept in mind by a member variable. When the second reqest is dispatched this member variable is overwritten and the first reqest reads in the second, which yields to the response of the second request.
Fixing this problem is very easy since the member variable is just used in one method. Therefore you just have to make the member variable to a local variable in the using method and everything works fine (see attaced patch).
For more information on JIRA, see:
