Oracle Community Schema test data
Key: GEOS-586
URL: http://jira.codehaus.org/browse/GEOS-586
Project: GeoServer
Type: Sub-task
Reporter: Chris Holmes
Assigned to: Rob Atkinson
The oracle datastore needs to be QAed to make sure that it works with the community schemas. To do that we need test data.
RobA, I'm assigning this to you as we're waiting on test data from you. We set up 10gR2 I think, so hopefully that works with your needs. If you can't get test data then update this issue with the types of things we need to test. You can email it to us at TOPP, or just attach it to this issue.
For more information on JIRA, see:
