[Geoserver-devel] [jira] Created: (GEOS-590) Community Schema Phase 2.2 QA
         Key: GEOS-590
         URL: http://jira.codehaus.org/browse/GEOS-590
     Project: GeoServer
        Type: Task
    Reporter: Gabriel Roldán
Assigned to: dblasby
     Fix For: 1.4.M4
The development of community schema support had two main real life community schemas as target.
The first one is GeoSciML (https://www.seegrid.csiro.au/twiki/bin/view/CGIModel/WebHome)
For the second one I'm waiting instructions from bgs people. Description is:
".. 5000 loughborough boreholes with their interval logs - this is the true complex properties dataset i.e. one set of borehole collar point geometries with two joined tables with a one-to-many relationship that we can use to prove that geoserver can now handle complex properties (loughborough bedrock sheet doesn't really prove that as it is single geometry-single table)"
This issue's children are to be sure this is supported on the target backends: ArcSDE and Oracle Spatial
For more information on JIRA, see:
