[Geoserver-devel] [jira] Created: (GEOS-595) Failure to handle GML Feature associations as properties in output schema
         Key: GEOS-595
         URL: http://jira.codehaus.org/browse/GEOS-595
     Project: GeoServer
        Type: Bug
  Components: WFS
    Versions: 1.4.M0
    Reporter: Rob Atkinson
Assigned to: Ian Turton
     Fix For: 1.4.M0
Attachments: geoserver_conf.zip
When a GML Feature Type has a property that is an instance of another Feature, its actually a construct that allows inline or by reference instantiation:
eg (from ISO19112 Gazetteer definition, a Data Dir attached - uses data in a postgres table via locationsXY store, but should be testable via shapefile)
<element name="locationType" type="iso19112:SI_LocationTypePropertyType"/>
  <complexType name="SI_LocationTypePropertyType">
    <sequence minOccurs="0">
      <element ref="iso19112:SI_LocationType"/>
    </sequence>
    <attributeGroup ref="gml:AssociationAttributeGroup"/>
  </complexType>
often these are constrained to be "byReference"
so an instance would look like this
<x>
<locationType xlink:href="http://my.org/featuretypecatalogue.xml#ft1002&quot;/&gt;
</x>
in the schema mappings file we have:
<AttributeMapping>
  <targetAttribute>SI_LocationInstance/locationType</targetAttribute>
  <sourceExpression>
    <OCQL>featurecode</OCQL>
  </sourceExpression>
</AttributeMapping>
which produces:
<iso19112:locationType />
or using an explicit mapping:
  <targetAttribute>SI_LocationInstance/locationType/@xlink:href</targetAttribute>
fails (with or with the xlink: prefix)
with logs saying:
    [java] Caused by: java.lang.IllegalArgumentException: attribute @href not found in http://www.opengis.net/iso19112:locationType
NB this pattern is common when creating an application schema using the ISO19118 rules (and thus INSPIRE, FGDC etc domains are affected)
For more information on JIRA, see:
