[Geoserver-devel] [jira] Created: (GEOS-596) Incorrect handling of nulls
         Key: GEOS-596
         URL: http://jira.codehaus.org/browse/GEOS-596
     Project: GeoServer
        Type: Bug
  Components: WFS
    Versions: 1.4.M0
    Reporter: Rob Atkinson
Assigned to: Justin Deoliveira
    Priority: Critical
nillable schema element:
<element maxOccurs="unbounded" minOccurs="0" name="alternativeGeographicIdentifier" type="xs:string"/>
throws error when database contains null in the column this maps to
[java] Caused by: org.geotools.feature.IllegalAttributeException: http://www
w3.org/2001/XMLSchema:string is not nillable
   [java] at org.geotools.feature.type.AttributeTypeImpl.validate(Attribut
NB - single value in column in source database, maps to schema that allows multiple values.
For more information on JIRA, see:
