Oracle connections pool not cleaned when we press "load" button in the web interface or delete a layer or a datastore
Key: GEOS-635
URL: http://jira.codehaus.org/browse/GEOS-635
Project: GeoServer
Type: Bug
Components: Oracle
Versions: 1.3.1
Environment: Windows XP SP2, Java sdk 1.4.2, Jetty, 1.3.1 geoserver release
Reporter: Pierre-Emmanuel Balageas
Assigned to: Sean Geoghegan
Create an Oracle datastore (not Oracle OCI, I don't test for it)
Create a layer for one table of this datastore
check number of connections to the database
then re check number of connections. We have one connection more.
if I delete one (or all) layer, the number of connections doesn't decrease.
if I delete the datastore, the number of connections doesn't decrease too.
For more information on JIRA, see:
