[Geoserver-devel] [jira] Created: (GEOS-637) relatesPattern Function Not Working ("attempted to construct illegal filter")
         Key: GEOS-637
         URL: http://jira.codehaus.org/browse/GEOS-637
     Project: GeoServer
        Type: Bug
    Versions: 1.3.1
Environment: WinXP SP2, Java 1.4.2_10, Tomcat 5.0.28
    Reporter: John Fletcher
Assigned to: dblasby
    Priority: Minor
Attachments: TouchingPolygons.zip
Requirement: GetFeatures query which retrieves all results whose geometries are related to the supplied geometry according to the following DE-9IM pattern: T********. The results from this query will be equivalent to [Intersects(geom1, geom2) And Not Touches(geom1, geom2)] but hopefully more efficient, as the latter will require two spatial evaluations for every matching result.
Attached is a sample shapefile based on BasicPolygons that contains two polygons with a shared boundary but whose interiors do not intersect. As expected, GetFeatures queries using Intersects AND NOT Touches work fine (e.g. return expected results), but the equivalent GetFeeatures query using the relatesPattern generates an error.
Sample GetFeatures query as run against the attached shapefile looks like this:
<wfs:GetFeature service="WFS" version="1.0.0"
  outputFormat="GML2"
  xmlns:topp="http://www.openplans.org/topp&quot;
  xmlns:wfs="http://www.opengis.net/wfs&quot;
  xmlns="http://www.opengis.net/ogc&quot;
  xmlns:gml="http://www.opengis.net/gml&quot;
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
  xsi:schemaLocation="http://www.opengis.net/wfs
                      http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd&quot;&gt;
  <wfs:Query typeName="topp:TouchingPolygons">
    <Filter>
      <Function name="relatePattern">
        <PropertyName>the_geom</PropertyName>
        <gml:MultiPolygon srsName="http://www.opengis.net/gml/srs/epsg.xml#4326&quot;&gt;
          <gml:polygonMember>
            <gml:Polygon>
              <gml:outerBoundaryIs>
                <gml:LinearRing>
                  <gml:coordinates decimal="." cs="," ts=" ">-1,-1 -1,1 1,1 1,-1 -1,-1</gml:coordinates>
                </gml:LinearRing>
              </gml:outerBoundaryIs>
            </gml:Polygon>
          </gml:polygonMember>
        </gml:MultiPolygon>
        <Literal>T********</Literal>
      </Function>
    </Filter>
  </wfs:Query>
</wfs:GetFeature>
Geoserver returns the following error message:
      org.xml.sax.SAXException: Attempted to construct illegal filter: Attempted to add sub expression in a bad state: complete
  at org.geotools.filter.FilterFilter.endElement(FilterFilter.java:325)
  at org.geotools.gml.GMLFilterGeometry.endElement(GMLFilterGeometry.java:204)
  at org.geotools.gml.GMLFilterDocument.endElement(GMLFilterDocument.java:287)
  at org.xml.sax.helpers.ParserAdapter.endElement(Unknown Source)
  at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
  at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanEndElement(Unknown Source)
  at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
  at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
  at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
  at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
  at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
  at org.xml.sax.helpers.ParserAdapter.parse(Unknown Source)
  at org.vfny.geoserver.wfs.requests.readers.GetFeatureXmlReader.read(GetFeatureXmlReader.java:72)
  at org.vfny.geoserver.servlets.AbstractService.doPost(AbstractService.java:375)
  at org.vfny.geoserver.wfs.servlets.WfsDispatcher.doResponse(WfsDispatcher.java:286)
  at org.vfny.geoserver.wfs.servlets.WfsDispatcher.doPost(WfsDispatcher.java:175)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:237)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:157)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:122)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:186)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:214)
  at org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveContext.java:104)
  at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:520)
  at org.apache.catalina.core.StandardContextValve.invokeInternal(StandardContextValve.java:198)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:152)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:137)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:118)
  at org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveContext.java:102)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
  at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:929)
  at org.apache.coyote.tomcat5.CoyoteAdapter.service(CoyoteAdapter.java:160)
  at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:799)
  at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:705)
  at org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:577)
  at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:683)
  at java.lang.Thread.run(Unknown Source)
The query was run with the function as the left expression in a PropertyIsEqualTo and "true" as the right expression, with the same results. The query listed above should work though, since Geoserver does accept an expression as a direct child of "Filter" as shown by the response to a query sent with the following filter (all results returned):
    <Filter>
      <Function name="isValid">
      </Function>
    </Filter>
  </wfs:Query>
For more information on JIRA, see:
