Bad SRIDs when inserting Oracle spatial with WFS-T
Key: GEOS-639
URL: http://jira.codehaus.org/browse/GEOS-639
Project: GeoServer
Type: Bug
Components: Oracle
Versions: 1.3.1
Reporter: Chris Holmes
Assigned to: Chris Holmes
Fix For: 1.3.2
Attachments: GeometryConverter.java
Hello,
I am currently evaluating, if GeoServer (1.3.1) WFS-T can be used to edit data in Oracle Spatial (10g) feature types.
My feature type is in EPSG:31286 coordinate system, but GeoServer seems to always insert features with Oracle SRID 0 into the Oracle Spatial layer.
SRID = 0 is not defined in the USER_SDO_GEOM_METADATA table. Therefore, if I try to create a spatial index, this is not possible as the SRID values differ (I have 31286 in USER_SDO_GEOM_METADATA, corresponding to the EPSG code of my data). On the other hand, if I already have a spatial index on my data and try to insert geometry using GeoServer, I also get an the error message, that SRID of the geometry does not match the SRID of USER_SDO_GEOM_METADATA.
What can I do to solve this problem? Or is this a bug in the current GeoServer version?
For more information on JIRA, see:
