Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/secure/ViewIssue.jspa?key=GEOS-65
Here is an overview of the issue:
Key: GEOS-65
Summary: Oracle cannot add FeatureTypes
Type: Bug
Status: Open
Priority: Major
Original Estimate: 1 hour
Time Spent: Unknown
Remaining: 1 hour
Project: GeoServer
Components:
Configuration
Struts
Fix Fors:
1.2
Versions:
1.2
Assignee: Richard Gould
Reporter: Jody Garnett
Created: Thu, 22 Jan 2004 7:42 PM
Updated: Thu, 22 Jan 2004 7:42 PM
Description:
And another showstopper: I can't seem to add Feature Types. After creating an Oracle DataStore I switch to the FeatureTypes tab. The combo box for FeatureTypeName is empty (should this really be a combo box??) and if I click new I get the following stack trace:
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
at java.lang.String.substring(String.java:1480)
at org.vfny.geoserver.action.data.DataFeatureTypesNewAction.execute(DataFeatureTypesNewAction.java:69)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:484)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:274)
I'll add this to Jira when there is a new category for it, but for now do you know why this is happening?
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
