[Geoserver-devel] [jira] Created: (GEOS-666) Touches Filter Not Working for Shapefile Feature Type
                 Key: GEOS-666
                 URL: http://jira.codehaus.org/browse/GEOS-666
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
    Affects Versions: 1.3.2
         Environment: Tomcat 5.5.?
            Reporter: John Fletcher
         Assigned To: dblasby
Touches filter does not return records with touching geometries.
Touches filter (pasted below) sent to Geoserver 1.3.2 at http://tree.env.gov.bc.ca/geoserver/wfs/GetFeature returns zero results. The same filter using Intersects instead of Touches returns a number of results whose geometry touches the filter geometry. The feature type in question is backed by shapefile. This behaviour has not been reproducible with the cite shapefiles included with Geoserver.
Specific functionality required for a custom application using Geoserver is filtering for features matching (T********) relates pattern. This can be achieved using Intersects AND NOT Touches in theory, but Intersects AND NOT Touches returns all intersecting results whether or not the geometries touch.
********** Touches Filter as sent to http://tree.env.gov.bc.ca/geoserver/wfs/GetFeature **********
<GetFeature xmlns="http://www.opengis.net/wfs&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; version="1.0.0" service="WFS" outputFormat="GML2" maxFeatures="500">
<Query typeName="prod:orthobc">
<ogc:Filter>
<ogc:Touches>
<ogc:PropertyName>the_geom</ogc:PropertyName>
<gml:Polygon srsName="http://www.opengis.net/gml/srs/epsg.xml#3005&quot;&gt;
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates decimal="." cs="," ts=" ">1338138.22848097,654291.00726857 1338431.04451064,654310.91803012 1338723.85936789,654330.84602621 1339016.67305171,654350.79125676 1339309.4855611,654370.75372172 1339602.29689502,654390.73342099 1339895.10705247,654410.73035453 1340187.91603243,654430.74452226 1340480.72383389,654450.7759241 1340773.53045584,654470.82456 1341066.33589726,654490.89042988 1341359.14015713,654510.97353367 1341651.94323444,654531.0738713 1341944.74512818,654551.19144271 1342237.54583733,654571.32624781 1342530.34536088,654591.47828656 1342823.14369782,654611.64755886 1343115.94084712,654631.83406466 1343408.73680778,654652.03780388 1343701.53157878,654672.25877645 1343994.32515911,654692.49698231 1344287.11754775,654712.75242138 1344579.90874368,654733.0250936 1344871.33720467,654753.22060606 1345165.48755339,654773.62213717 1345458.27516514,654793.94650839 1345751.06158012,654814.28811248 1346043.84679733,654834.64694935 1346336.63081576,654855.02301895 1346629.41363438,654875.4163212 1346922.19525219,654895.82685602 1347214.97566816,654916.25462336 1347507.75488129,654936.69962313 1347800.53289056,654957.16185527 1348093.30969496,654977.64131971 1348386.08529347,654998.13801637 1348678.85968508,655018.65194519 1348971.63286877,655039.18310609 1349264.40484353,655059.731499 1349557.17560835,655080.29712385 1349849.9451622,655100.87998058 1350142.71350409,655121.4800691 1350435.48063299,655142.09738935 1350728.24654788,655162.73194125 1351021.01124776,655183.38372474 1351313.77473161,655204.05273974 1351606.53699842,655224.73898619 1351897.93776483,655245.3462275 1352683.63292144,644139.69178598 1352391.58153408,644119.03853414 1352098.16560645,644098.30610077 1351804.74845906,644077.59093731 1351511.33009293,644056.89304385 1351217.91050907,644036.21242044 1350924.4897085,644015.54906716 1350631.06769222,643994.90298408 1350337.64446128,643974.27417127 1350044.22001667,643953.66262881 1349750.79435941,643933.06835676 1349457.36749052,643912.4913552 1349163.93941102,643891.9316242 1348870.51012192,643871.38916383 1348577.07962424,643850.86397415 1348283.647919,643830.35605525 1347990.21500721,643809.8654072 1347696.7808899,643789.39203005 1347403.34556806,643768.93592389 1347109.90904273,643748.49708879 1346816.47131492,643728.07552481 1346523.03238564,643707.67123203 1346229.59225592,643687.28421052 1345936.15092677,643666.91446034 1345641.343818,643646.46737799 1345349.26467423,643626.22677429 1345055.81975288,643605.90883855 1344762.37363617,643585.60817443 1344468.9263251,643565.32478201 1344175.47782071,643545.05866134 1343882.028124,643524.80981251 1343588.57723599,643504.57823557 1343295.1251577,643484.36393061 1343001.67189014,643464.16689769 1342708.21743434,643443.98713688 1342414.7617913,643423.82464825 1342121.30496205,643403.67943187 1341827.84694759,643383.55148782 1341534.38774896,643363.44081615 1341240.92736716,643343.34741694 1340947.46580321,643323.27129027 1340654.00305812,643303.21243619 1340360.53913293,643283.17085478 1340067.07402863,643263.14654611 1339773.60774625,643243.13951025 1339480.1402868,643223.14974726 1339186.6716513,643203.17725722 1338893.20184077,643183.2220402 1338598.36501583,643163.19134384 1337844.04848226,654271.02119584 1338138.22848097,654291.00726857</gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</ogc:Touches>
</ogc:Filter>
</Query>
</GetFeature>
